CRM's NC30 project - codename EXON VALDEZ
Dgeoff33
Bike owned: RVF400 - ZX636
Re: CRM's NC30 project - codename EXON VALDEZ
Post by Dgeoff33 »
surely when you tighten it up the spindle should move it across
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Geoff, tried mate. just gets tighter on the fork and refuses to turn the wheel.
2 different spindles, different spacers, odd one this isnt it ?
I have two different nuts for my two bikes - one is 22mm and one is 24mm.. both wheels and spindles are easy to swap though...
G-MAN
Post by G-MAN »
Maybe you should take both discs off and put them on a flat surface to see if they are the same offset and is there a lot of paint on the mounting surface could even be a combo of that if its not the bearings :roll:
CRM
Admin NWAA
Admin NWAA
Post by CRM »
good call on the disks will try that. surfaces i filed the powder off so nice and smooth and the disks are a nice fit.
watch this space
Dgeoff33
Post by Dgeoff33 »
Are the discs the ones that came off? The left one looks to have a lot of space between it and the wheel (unless it's just the way the picture is).
CRM
Admin NWAA
Admin NWAA
Post by CRM »
Spot on Geoff, your idea worked, by eye its about 3mm higher which ties in with the spacing. its also warped to fuck too.
No idea what thats from, as its identical in just about every way just sticks out a bit more.
Well next mission to find some super cheap disks as so far without counting my OE bodykit i am upto £1130 which kinda makes this bike a bit of a joke now.
On the upside i know every nut and sodding bolt of it.
Spike16
Post by Spike16 »
Glad you sorted it mate, iv got those seat hooks ready to send, is their anything else you need? Iv got alot of stuff to get rid of cheep :)
CRM
Admin NWAA
Admin NWAA
Post by CRM »
ooooh it runs and runs like a dream too.
rectifier is fooked though, and somehow i am missing 2 caliper bolts. apart from that i reckon were ready to rock
abrmoto
Bike owned: RVFx5,SP1,MV F3,C90,Firestorm
Post by abrmoto »
Paul,
Think i have a rectifier if you need one, you get the discs/spacers sorted in the end??
