Micro Monkey's RVF400, YZF1000SP (98 Haga Rep), Ducati 996
- Micro Monkey
- Bike owned: CG125, RVF400, YZF1000SP, 996
My RVF400
These are not up to date pics but the only thing different is gilles GP Light Clipons & Progrip 724's have been fitted.
Maxton Forks
Maxton Race Shock
Mercury Twin Stack Full Race Exhaust
Dymag 3 Spoke Magnesium Wheels
NHK Steering Damper
Brembo 16mm R1 Radial Master Cylinder
EBC Prolites (Now removed as the blue rotors clashed)
Nissin SP1 Calipers
Gilles GP Light Clipons
R&G Crash Bungs (Non Drill)
Hel Braided Hoses
Hel Radial Adaptor
Pazzo Brake And Clutch Levers
Berik Master Cylinder Cover
HRC Cdi
HRC Coolant Reservoir
HRC Rear Brake Reservoir
Rick Oliver/ SES Rearsets
Titanium Gear Shift Rod
Electrex Rectifier
Carbon Front Fender (Tyga)
Carbon Rear Hugger/Chainguard (Unknown but bought from Japan)
Carbon Heel Plates (I Made them)
Carbon Exhaust Hangar (Bought Off Ebay)
Carbon Hangar Pivot Mod
Carbon Fairing Infills (Tyga)
Carbon Tank Protector (Unknown)
Carbon Front Reservoir Mount (I made It)
Carbon Airtubes (Tyga)
Carbon Tax Disc Holder (Fibre Lyte)
Carbon Yoke Protector (Skur)
Carbon Clock Surround (Fibre Lyte)
Carbon Fibre Shark Fin/Chain Guard
Tyga Steel Screen Brace
Tyga Lock Stop Reducer
Sparco Billet Fuel Cap
MRA Airflow Screen
Progrip 724 (Red/Black)
Redial MPH Conversion
Honda Locking Valve Caps
Single Seat Cowl
Alloy Preload Adjusters
Probolt Alloy/Stainless Steel/Titanium fasteners throughout
Probolt Bar Ends
Probolt Ti Rear Wheel Nut
Ti Wheel Nut Spacer
Honda Rim Decals
7x5 plate
Battery Monitor (Red Backlight) With Carbon Mounting (Made By Me)
Pirelli Diablo H's
Carbs Running 115 main jets with 0.5 washers under needles.
Removed Items
Had Apex GP Clipons but prefered the feel of the bike with the standard bars. May fit speedymotos or Gilles in the future
Quick Action Throttle - removed as only 8 degrees difference to standard so sold on, felt a bit awkward
Carbon Air Tray - Sold as the engine is running sweet as it is, it did nothing anyway, engine performance is not what i bought the bike for
Clear Indicator Lenses - cheapened the look of the bike. like the older fashioned 90's look
Renthal Medium Superbike Grips - Replaced by progrip gel 724's for comfort
SES Aluminium Screen Brace - Just looked wrong in silver, replaced with tyga black steel version
MHP Carbon Half System, SP1 Style - Came with my first RVF but wanted a twinstack to get the 95 8 hour look so sold on and bought a mercury
Slingshot Racing Quick Release Fuel Cap - The Sparco weighs nothing so use that one
Alloy Exhaust Hangar - Bought A Carbon One
[Maxton Forks
Maxton Race Shock
NHK Steering Damper
Nissin SP1 Calipers
Hel Braided Hoses
Hel Radial Adaptor
HRC Cdi
Electrex Rectifier
MRA Airflow Screen
Single Seat Cowl
Probolt Bar Ends
Ti Wheel Nut Spacer
Honda Rim Decals
7x5 plate
Pirelli Diablo H's
Removed Items
- royster81
Re: Micro Monkey's RVF400 & YZF750/1000SP (98 Haga Replica)
really lovely RVF mate, and i like the break down of the parts fitted.
Best colours for an RVF also !
- Micro Monkey
My YZF750/1000SP
I bought it like this, covered in stone chips and basically looking like a well loved and well ridden one off yzf. Looks can be decieving.
Well after much tinkering and sorting of the very dodgy electrics the bike is now 100% apart from the fork seals needing to be replaced but that can wait until a sunny day. Alarm removed as wires caught fire, fuses would continually blow, fan did not work, left indicator indicator on dash did not work, so resistors fitted as 12v was blowing a 2 volt led and a negative wire to earth added to create a circuit. Spa clocks now working 100%. All wiring checked, resoldered and reloomed. Coolant was basically rust coloured so rads flushed with cleaner several times, Coolant is now a pretty pink colour (50/50 Mix). Hoses were rough so have neatened and trimmed the expanding mesh and fitted new clamps where needed. Fan thermo bypass switch added so i can turn the fans on when i want although the thermo switch now comes on at 92 degress C. Oil drained and filter renewed, using gericke 10w40 oil (Basically the best Motul Stuff rebranded). A whole day removing, cleaning and rebrushing the pipework. Whole of the lower fairing heat proofed to protect the lovely new paintjob. Spent yesterday cleaning the disks to a lovely new silver colour only to find they were brown coloured by this morning (Bloody Cast Iron). Paintjob by Chris @ the Sprayshack (07919242193, Gloucester), very nice bloke and a top job he did too for £600.
Here it is now and the current spec!
- Micro Monkey
Spec:
Suspension & Steering:
Ohlins R&T Forks 1998 R1 Fitment (Superbike Internals)
Ohlins Rear Shock (Off TT Race bike) with standard linkage
R1 Top and Bottom Yokes (Looks like R7 Ones)
Harris Fork Crash Bungs
Alloy Top yoke Nut
Harris Billet Race Clip Ons
Maxton Steering Damper
Harris Fork Clamp For Steering Damper
Braking:
AP Front Adjustable Ratio Front Master Cylinder
AP 6 Pot 1 Piece Front Brake Calipers, built with titanium bolts
Harris Ducati Fitment Caliper Brackets
Goodridge Stainless Braided Hoses
Billet Rear Caliper Bracket (One Off)
AP 2 Pot Race Rear Brake Caliper
AP Fully Floating Race Discs
Alloy Pressure Brake Switch
YEC Factory Rear Floating Brake Disc
Brembo Mini Fluid Reservoir
Wheels:
Marchesini Magnesium 5 Spoke Front Wheel (500 Gp Fitment)
Marchesini Magnesium 5 Spoke Rear Wheel (Off Factory Boost Yamaha YZF750SP)
Fitted with alloy angled valves
R1 Front Wheel Spindle (Lightened)
Lengthened Standard Rear YZF750 Wheel Spindle
Michelin 180 55 ZR17 Pilot Race 2CT Rear Tyre
Michelin 120 70 ZR17 Pilot Race 2CT Front Tyre
Hand Painted Pinstriping On Wheels
Engine:
Thunderace Cams & Cambox
Thunderace Barrels
Thunderace Crank & Conrods built into original YZF750SP Crankcases
FZR1000 Gasflowed Cylinder Head
Dynojetted Thunderace Carbs
Modified YZF750SP AirBox with K&N Filter
YZF750SP 6 Speed Gearbox With Highly Modded Banded Clutch
FZR1000 ECU
Akropovic Full 1998 Thunderace Exhaust System
Factory Akropovic Titanium Race Can (Ex Boost)
YZF750SP Standard Radiator With Underslung YEC Factory Lower Rad (1996 Race Bike)
YZF750 Standard Fans With Chromed Brackets
BSR Aerotec Coolant Hoses With Anodised Hose Finishes.
All Waterpipes Chromed & Built With Stainless Bolts
CSC Moto Clear Billet Clutch Cover
Factory YEC Race Coolant Bottle Fitted To Rad
Factory YEC Engine Crank Crash Protector
Factory YEC Magnesium Cable Cutch Conversion
Modified Sprocket Cover
Standard Wiring Harness & Modified Front Sub Harness
BSR Aerotec Oil Filler Cap
Produces 142 RWHP & 81ft/lbs of torque
Controls:
SPA Design Speedo & Rev Counter
SPA Design Water Temp & Voltmeter
Speedo Pick Up Mounted Off Rear Brake Caliper And Sensor Mounted in Discbolt
R1 Thottle Assembly (Quick Action)
Standard YZF750 Switchgear
Factory YEC Cable Clutch Assembly With Factory Adjuster
Standard YZF Ignition Switch
Ducati 916 Instrument Lights Mounted On Carbon Dash
Renthal Race Grips (Medium)
Honda Choke Lever
Promach Rearsets And Pegs (WSB Factory Yamaha)
Factory Nissin Smallbore Rear Brake Master Cylinder
Chassis:
YZF750 SP Factory Frame With Bolt on Subframe, Eccentric Swingarm Adjustment Modified to Race Chassis no ********* registered Yamaha UK, Chassis Tagged to *********
Harris YEC Spec Swingarm Modified With Modenas 500GP Bike Wheel Adjusters
YEC Exhaust Bracket
Modified Standard Underseat & Battery Housing
YEC YZF750SP Quick Release Fairing Brackets & Screen Brace (Modified To Suit)
YEC Crash Bungs
Mostly Titanium Throughout Chassis
Renthal Special Edition 99 Yamaha WSB Rear Race Sprocket (Haga R7)
Renthal Front Sprocket
520 DID Race Chain ERV3
YEC Factory Chain Protector (Shark Fin)
Alloy Stand Bobbins On Swingarm
Standard Chromed Sidestand & Mounting Bracket With Cut Out Switch
Fairings & Cosmetics:
R1 Carbon Front Fender
Factory Steel Fuel Tank (Early Boost Yamaha)
Full Factory Carbon Kevlar Fairing With Factory Fitment Alloy Brackets (Ex Boost Yamaha, Ex Mckenzie)
Full Factory Carbon Kevlar Seat Unit (Ex Boost Yamaha, Ex Mckenzie)
Fairing Modded to Accept 2 Spotlights For Headlights
Yamaha FZR400 Complete Light assembly
Harris Race Fuel Cap
Harris One Way Alloy Breather
QB Carbon Number Plate Bracket
Mini Indicators
1998 Yamaha WSB Haga Colours (Paintjob by Chris @ The Sprayshack (07919242193, Gloucester)
Lots more Mods by the looks of it and weighs loads less than my rvf400 by the feel of it with fuel in it too. Would say late 160's early 170's with fluids
Pair of tasty motos there dude.
That YZF has had a lovely paintjob too.
- ibby4585
- Bike owned: SP's
Very nice mate, really like that RVF!!
- abrmoto
I looked at the YZF too.
I want it!! Loverly mate, really tasty.
That didnt take you long to get that painted up mate, looks
- Polisher
- Bike owned: z1000a1h, vfr800vtec, nc30,
They both look awesome, obviously lots of time spent on them
well done, pal, wish mine could look like either of them
Spike16
very cool mate, we've got those calipers on the formila student car at uni and their very very nice pieces of engineering
