Reg/Rec advice
Re: Reg/Rec advice
That will do, not a straight swap but not e every difficult one either.RacingSlug wrote:I can get my hands on a 1999 R6 unit but will it do the job?
I guess it won't be a straight swap job
You'll need to cut the honda plug off and use 5 standard sized female spade connectors (insulated ones!).
tayto94
Re: Reg/Rec advice
I read there that a cbr600 reg fits straight in and is a bit more robust.....anyone know bout this?do you know what year cbr?cheersStickshift wrote:That will do, not a straight swap but not e every difficult one either.RacingSlug wrote:I can get my hands on a 1999 R6 unit but will it do the job?
Biscuits
- Bike owned: '88 NC24
- Location: approaching the apex, carrying too much speed...
Re: Reg/Rec advice
You'll need to cut the honda plug off and use 5 standard sized female spade connectors (insulated ones!).[/quote]
wicked! Thanks fella. Saved me having to lug a spare battery and charger to work every day :)
Formerly RacingSlug. Felt like a change and it came down to either Biscuits, Ben10 (possible copyright issues) or NinjaSmokeWarrior. The wife suggested TwatMan.
Re: Reg/Rec advice
Stick with a honda one at your own risk.tayto94 wrote: I read there that a cbr600 reg fits straight in and is a bit more robust.....anyone know bout this?do you know what year cbr?cheers
Honda can build fantastic bikes, but still has trouble with reg/recs!
tayto94
Re: Reg/Rec advice
point taken...so would any year r6/r1 reg fit???Stickshift wrote:Stick with a honda one at your own risk.tayto94 wrote: I read there that a cbr600 reg fits straight in and is a bit more robust.....anyone know bout this?do you know what year cbr?cheers
cbr400rrn
- Bike owned: NC29 CBR600F
Re: Reg/Rec advice
Just make sure its a 5 pin and not a 6 pin R6 rectifier and you will be ok (not the later models in other words, just ask the seller when you come to purchase one.)
Re: Reg/Rec advice
£22.00 buy it now
http://cgi.ebay.co.uk/Yamaha-R6-regulat ... 53dd7e7f8f" onclick="window.open(this.href);return false;
£25 buy it now jobbies
http://cgi.ebay.co.uk/Yamaha-R6-regulat ... 4cebc2eadb" onclick="window.open(this.href);return false;
http://cgi.ebay.co.uk/YAMAHA-R6-5EB-REG ... 3ca6ec80f7" onclick="window.open(this.href);return false;
http://cgi.ebay.co.uk/YAMAHA-R6-5EB-REG ... 25569a8b88" onclick="window.open(this.href);return false;
£9.99 bid
http://cgi.ebay.co.uk/YAMAHA-R6-RECTIFI ... 35a4e720c8" onclick="window.open(this.href);return false;
I tend to go for the 2005 year as i'd had reports the 99 models were more fragile,
£9.99 bid
tayto94
Re: Reg/Rec advice
cheers man, i may have one got from a local la, will know tonite but if not these will help!!Neosophist wrote:£22.00 buy it now
£9.99 bid
cheers
tayto94
Re: Reg/Rec advice
was onto a lad there and he said the yam ones can give a bit of bother aswel...but kwack ones are pretty robust...tayto94 wrote:cheers man, i may have one got from a local la, will know tonite but if not these will help!!Neosophist wrote:£22.00 buy it now
£9.99 bid
cheers
anyone ever try a zx7r reg rec in their vfr?
Biscuits
Re: Reg/Rec advice
Garrr. Just bought a 1999 R6 unit AND paid extra to get it tomoro. Might ask Santa for a 2005 unit, knowing my luck I'll need it, lols.
