fuel tap - tyga kits...
hopefully anyone with a tyga kit can give me an idea to my problem, i am not using a tyga kit as listed in the topic but a cbr 600rr body, and the issue i have come up against is if i use the tank trims i hide the fuel tap.
for those who have purchased a tyga kit, how do you get around this...is the fuel left on all the time? looking at the k-conversion kits they leave a big gap under the tank which would solve my problem but not the look i am after.
see pics below, any ideas would be great..
- Bike owned: nc30. husq cr125.
Re: fuel tap - tyga kits...
how about drilling a hole in the side to incorporate the tap? its just common sense really lol
Fill up every 100km's?
i reckon you could drill a hole in the seat front and make up some sort of stylish adapter.
Or leave it on reserve and fill up every 150km's....
Edit: Get that thing painted pugparcels! I and probably others are left hanging seeing how good it will look when sprayed. Hell, you could even buy a can or two of spray pack and get rid of that gay pride paintjob!
I know - sorry for the delay, with our second kiddy, impeding wedding & putting the angle grinder through my foot i have been struggling lately.
the problem i have is the tap touches the side panel, it does not come further than that. If i just cut a hole it is going to look really ugly. Thats why i wondered what was done when a tyga kit was used.
I will get her painted asap. I still have loads to do / aquire .....
rear tyre
both wheels to be powdercoated
new seals for rear caliper & piston
finish riders seat
bar ends
coolant overflow bottle - like the tyga one
sort out the electrics ( when i turn the indicators on the brake light flashes - bad earth )
new front brake pads for sp1 calipers
However the 'done' list is far greater so i am headign the in the right direction.
rear tyre
finish riders seat
bar ends
I've got the TYGA kit, I can reach round easily and turn the fuel tap.
ok, that answers the question then, no cutting or anything like that. cheers DanHam.
to be a real pain in the arse could have a picture showing how it is......please....i will add you to my christmas list!
ok now confused, am now assuming more than one type of tyga kit available or have they changed in design with age?
anyhow i am either gona have to cut my panel or make cover that can be removed quickly - dzus style fastners.
i am only gonna turn fuel on / off when i go to work and come home in theory.
A bit dificult to see in this pic, but I hope you get the idea
is a bit difficult to see in the pic, as i am at work and wolseley use websense and i cannot see pictures. apparently it stops us working if we have access to the net.
will have a look tonight when i get home thank you in advance. there is always a way.
