Juddering while accelerating.
weasel
Post by weasel »
This problem is driving me insane. When accelerating there is a momentary judder, no more than half a second, it never happens while cruising or slowing, its really spoiling the bike for me. So far I have changed the carbs, cdi, plugs and filters, but still he problem persists unchanged. oh and it does not occur if you rev the bike in neutral.
Am I missing something obvious? The only thing I can think of is that this is something electrical.
Any help appreciated, its an NC23.
Ta
Weaselpie@twitter
greggo
Re: Juddering while accelerating.
Post by greggo »
Which gear?
Sounds similar to how mine felt when 5th gear wasn't engaging properly. Required a strip and replace a couple of gears and a selector fork.
scratchin
Post by scratchin »
i take it you mean a stutter with the engine as in a flat spot, more than likely fuelling
tanuki
Post by tanuki »
greggo wrote:Which gear?
^^^^this was also my first thought, does it almost feel like a surge or like its jumped a tooth on a sprocket?
All gears?
Dodgy Roj
Bike owned: too many to list
Post by Dodgy Roj »
check your chain and sprockets !
weasel
Post by weasel »
Thanks for the replies, it happens in all gears, regardless of engine temp. it is more like a very short surge I guess.
Weaselpie@twitter
Dodgy Roj
Post by Dodgy Roj »
may be a long shot but look for a tight spot on the chain.
Waza4
Post by Waza4 »
Are there any strange noises.
Is it always at the same revs or throttle position?
Might be worth checking the wheel bearings.
tanuki
Post by tanuki »
Are you sure it's all gears?
Does it happen at the same revs everytime?
Waza4
Post by Waza4 »
Clutch judder ?
Maybe time for a workshop or dyno.
