cam chain is it self adjusting? also valve clearances 3tj
				rickyr
is the cam chain on the 3tj self adjusting ie...on a spring or do you adjust as/when needed your self? also valve clearances are they easy done? or whats the score on it.
				dobbslc
Re: cam chain is it self adjusting? also valve clearances 3tj
The cam chain adjustment is auto, The valves need the cams out to change any shims but you can check the clearances with just the cam cover off.
				plodder
Valve clearances are easy if you know what you're doing.
Easily turn into a nightmare if you don't
just take the cam cover off ......
				rickyr
thansk for the replys, thought the cam chain was self adjusting. what way do you adjust the valve clearance if need be? which they probley will need done.
Use the manual - measure the tollerances for each valve and note them down. Then lift the cams out. There are shims between the cam follower and the top of the valves they should have a number on them write these down too.
Add the two numbers per valve together, that gives you total valve clearance then see if you can juggle the shims around so you only buy the the ones you need. Refit everything and recheck the valve tollerances.
A tip is to put paint on the cam chain and cam wheel so you can just line the cams up quicker.
