NC 30 ONLY RUNNING ON 2 FRONT CYLINDERS
DAVEB
Post by DAVEB »
Hi am after some info, my NC30 is only running on the 2 front cylinders, have had the carbs off and ckecked all jets for blockages, they were clean. Have replaced the 2 rear cylinders plugs, did not cure the problem, have swaped the 2 coil packs around from front to back and still runs on the front cylinders, there is no spark on the rear cylinders at all, is not ht leads either so basicly am out of options, any info on this problem would be grately received .
Re: NC 30 ONLY RUNNING ON 2 FRONT CYLINDERS
Welcome Dave..
CDI then? Has anything else been modded on the bike at all form standard?
DAVEB
Post by DAVEB »
hi and thanks for the quick reply, the bike is totally standard, not sure why this has happened as was running perfect, next day only on 2 cylinders, back 2 pipes are cold, not sure what the cdi is to be honest as am new to biking.
Righty..
CDI is the brains that tell the bike to fire the plugs - called the ECU too..
Have you tried a working front plug in a rear lead? The plugs on these bikes can die a death very easily...
Where you at? Might be someone local could lend oyu a CDI to test it?
DAVEB
Post by DAVEB »
yes have tried a good plug in the rear leads but still no joy, am in skelmersdale in lancashire
banoffee
Post by banoffee »
is it the rear cylinders that the top speed restriction cuts out?
DAVEB
Post by DAVEB »
CMSMJ1 wrote:Welcome Dave..
Have located the CDI at the rear of the bike, any ideas how much these cost, if this is the problem would it still allow the front cylinders to fire?
you'll want to speak to Aly - aka abrmoto on here.
He is selling a lot of NC gear and is local to you - Am sure he can sort a CDI out and sell it to you if you needed it
:Bmods:
viper_biker
Post by viper_biker »
I've a standard NC30 CDI here that I can confirm is 100% working as I only took it out of my bike a few months ago after fitting a programmable one with an HRC ignition on it.
DAVEB
Post by DAVEB »
Hey thanks for the offer will try and confirm if it is the cdi thats at fault, if it is will get back in touch, my bike is a 93
