Wrong radiator!!!!!
				reverend
Wrong radiator!!!!!
My dear wife surprised me by buying me a good condition 3TJ radiator for my money pit. Its in far better condition than mine, only trouble is its only got 4 hose attachments and I need 5. Its missing the one on the bottom right hand side (rad cap side) that should connect to the hose that cools the oil. Is there any way I can bodge this to make it work?
				hunter
Re: Wrong radiator!!!!!
make a T peace to fit the other hose and connect it to that.
				plodder
Presumably it's a rad off the RR and not the SP.
I just made a T piece as hunter said when I did the 600 conversion (which has an oil cooler hose) and fed it into the main coolant return under the rad cap.
				reverend
Cheers fellas!
To confirm...... I'll need a T piece to combine my floating outlet oil cooler hose with the main radiator inlet hose (from the thermostat)?
What did you use for the T piece - as the hose diammeter is so different?
				plodder
Correct.
I used the piece off a FZR1000 that takes the bleed off from the water pump 'cos I had one. (Cut down to fit).
I didn;t go this way so can;t say fpor sure but I think you can use 22mm plumbing pipe on the main line and probably 10mm on the side leg, so a 22x10x22 tee and some short piping stubs (go to B&Q/Wickes, etc.).
				reverend
Thank you - I was just scanning through some of the 600 conversion threads for info. Theres not much you boys don't know!
				plodder
Although we all do things slightly differently.  I must have been a but drunk for my last post looking at the spelling
				hunter
wot speelin dint notiz
