why is the reg/rec getting so hot?
rickstar
Bike owned: gsxr 400 gk76a
Post by rickstar »
when i start the bike leave it running for a minute the reg/rec gets so hot i cant even touch it. is this normal. thanks
Re: why is the reg/rec getting so hot?
They do get bloody hot. try running with your lights on and it should get less hot so quickly.
The end of the day it is how it works....
rickstar
Post by rickstar »
thanks, i recently replaced it but im still havin problems. if i charge the battery full, it will start off the button then run it for a couple of miles, turn it off it wont start, the battery will be flat. do you have any ideas? thanks
not charging or charging too much?
have you tested it or just replaced it?
have a look in the VFR section for Reg/rec stuff...we Honda posse blow ours up all the time and there will be details for testing them - pretty much the same animal between bikes.
rickstar
Post by rickstar »
thanks will do. :worthy:
Variablevalves suck
Post by Variablevalves suck »
Hi Rick,
You can test a few things if youve got a test meter.
With the bike steady at 5000rpm you can test the voltage across the battery- lights on hi and test between the + and - you should have between 13.5V ans 15.5V.
You can test the three wires from the generator, test that there is no continuity between the wires and ground and you can do a no load test of the genny by running the bike at 500rpm and testing the AC volts between each of the wires, you should have more than 70Volts at 500rpm. Then you can test continuity between the wires of the reg/rec and they should be open circuit between the three wires.
Hope this helps.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
as above except for the output of the alternator,the readings should be 50volts.
wull
