Spongy Brakes
clarkee
- Bike owned: fzr400
Spongy Brakes
As you all know brakes on the 3tj always been top notch but since I had an off few months ago (bike ended up upside down against the tyres) mine have been really spongy.
Had them off, cleaned out calipers and replaced the fluid, even tie wrapped the lever back overnight but still the same, comes right back to the bar. Any ideas?
Q007
- Bike owned: FZR 400 1wg 1986 FZR 600r 1995
Re: Spongy Brakes
could be bent/warped disc/discs. mine had 1 disk that when laid flat looked like a breakfast bowl and was spongy as hell.
Q
Q
Re: Spongy Brakes
A warped disk will do that ... the brakes will bleed and be hard until you move the bike then they'll be soft again, pump them with the bike soft and they're hard again.
If they just won't bleed in then you could have a piston locked or some air behind it.
Lastly you could have popped a seal in the master cylinder so the fluid isn't being pumped.
Swap a few bits out from a working system to see if it makes a difference - it could be an excuse to get a radial master
clarkee
Re: Spongy Brakes
Cheers guys, looks like the master cylider I think.Evilchicken0 wrote:A warped disk will do that ... the brakes will bleed and be hard until you move the bike then they'll be soft again, pump them with the bike soft and they're hard again.
