dyno tuning
rickstar
Bike owned: gsxr 400 gk76a
dyno tuning
Post by rickstar »
does anyone no much about dyno tuning. is it a good idea, wot does it achieve, how much is it any info please, was thinking bout gettin mine done but just wanted some info.
thanks :worthy:
TeamGSXR
Re: dyno tuning
Post by TeamGSXR »
Basically if you modify the bike - example - performance headers, performance end can, performance air filter etc your fuelling will be out. As such your bike is not making as much power as it could (+ likely to be running very lean).
Dyno runs can show you the power, torque and fuel curves. From this data the operator can tweek your carbs.
I think I paid £45 for a dyno run at RJS Superbikes. That's without them messing about with the carbs which could have run up to a few hundred quid.
It can also be used to show you the overall power but remember one dyno will measure different to another!
rickstar
Re: dyno tuning
Post by rickstar »
ive got a full scorpian system thats it, ive just had the carbs balanced do u think its worth getting it dyno tuned. thanks
TeamGSXR
Re: dyno tuning
Post by TeamGSXR »
Probably not worth it... How's it running?
rickstar
Re: dyno tuning
Post by rickstar »
it runs ok just it sounds a bit rough when i rev it in neutral about 5-6000 revs, i thourt it mite help it run smoother. and theres a flat spot in lower end of second. any ideas?
thanks
