Exhaust, but which one?
rich1988
Re: Exhaust, but which one?
you can get link pipes but they wont be what you want, they involve cutting the downpipe further down (I know Ive looked) and the problem with that is you wont be able to reuuse your standard exhaust come mot time unless you cut that pipe off and somehow have a new one welded on
Im thinking Im going to have to buy/get made an adapter pipe so I can fit a standard slip on in place of it
rcv4
the best way is to cut and sleeve at the collector leaving link pipe and can in one,slip joint the origonal pipe for mot.
rich1988
I am going to buy this kit as if you look it has the exact adapdter that I need!, I asked if they will sell it seperatley but no sadly so looks like Ill buy the set:)
http://cgi.ebay.co.uk/NEW-HONDA-VFR400- ... .m14#rpdId" onclick="window.open(this.href);return false;
rcv4
dose anybody sell the adaptor seprate???
rich1988
They do, I have managed to find someone who does, and im talks with someone who might be able to custom make them as well,
http://highriders.co.uk/Viper-Exhaust-C ... r-862.html" onclick="window.open(this.href);return false;
Connecting Pipe Kit CNP206 Required
Its the same as the adapter in the picture according to the guy from that website
- Julesholling
- Bike owned: Honda VFR400 NC30
Ok, so is that adapter what i'd need to connect the Scorpion can that i have? (suppose it depends if the Viper can and Scorpion can have the same fitting size)
Good find though, we'll get there in the end
rich1988
took me bloody hours! :p, I have bought that Viper kit off ebay with the Race can, that should come by friday, I have also emailed highriders to ask them if it is the standard 50mm outlet, if so your scorpion should just slip right over the end, Ill let you know when they get back to me or I receive my kit :)
I do have all the correct measurements needed to make an adapter if anyone was that way inclined, the bend is 16 degrees which appears to be a bit awkward to do from people I have asked.
Why don't you guys look closer to home for a kit. I know Rick Oliver supplies them, as I bought one back in the mists of time - it came with 50mm adapter for my ART can and also the 60mm to refit the o/e can.
I'll bet 20p that Graeme France can also sort you out.
Keep it in the greybike fraternity people...
rich1988
you tell me after I spent £130! :D
rcv4
i dont need one,i would of made a batch if there was enough intrest.
