False speedo readout
Re: False speedo readout
lp can u please forward the templates to me, does your kit bypass the light trap?
ive still got to see if my nc29 is derestricted.
the dials dont bypass anything.
BUT if you are fitting the dials your self. you may as well while you have the speedo in your hands** also remove the disk that cuts the light trap beam = no need for a mod kit.
If your not fitting the dials then get who ever is to remove the disk for you.
** you must be careful when you dismantle the speedo out of the dash, it is a precision tool and can be damaged easily! i cocked up 2 speedos doing this!
need an email address bud...
cheers lp, its phillcbr400@gmail.com
i'm not sure if mine has been done or not, but i'll look before i start taking it apart.
does your kit you sell on ebay derestrict the bike without having to mess inside the clocks?
"does your kit you sell on ebay derestrict** the bike without having to mess inside the clocks?"
> yes
you wont be able to "see" the light trap disk until you do dismantle the speedo out of its housing/dash. the only other way to test if its there is to get on a private road or track day and see if it goes over 112mph or not.. i wont be held responsible if you get caught! immediate ban if you get caught over 100mph!
** ONLY removes the 112mph/180kph limiter.
email heading your way with NC29 templates.....
> yes
received, thankyou very much for that
well pretty sure it has been done then had at least 120 out of it, but its over reading slighty due to downgearing. do u know of any way to rectrify the reading, as i like the gearing it has.
not i sir. some thing i never got round to playing with.. but i know loads on here have.
start a new thread on it....
