2nd gear or clutch ?
Andync30
Post by Andync30 »
ive replaced the plain plates and friction plates the springs and dropped the oil,but it is still doing exactly the same thing.When in 2nd only at 8k and 10k it feels like its slipping on something it gets worse in the last 3k of the rev's to.The push rod mechinisem was replaced also as it was shot completly and the cable has been changed to.The chain aint to tight either.Could it be the basket ? or anything else ? or is it going to be 2nd gear ? i was led to think that it prob aint this as it dont pop out of gear.Please help !!!!!!!!!!!!!!
MexicanGringo
Bike owned: '30
Re: 2nd gear or clutch ?
Post by MexicanGringo »
was there any burning on the plain or friction plates? In what way was the pushrod finished? The basket's sides would have to be pretty bent to allow the plain/friction plates to turn within it.. It might be the diaphragm springs on the end, place all 3 of them on a flat surface ontop of each other and measure their height,4.8mm is the min, if these are worn the clutch plates may not properly re-engage when clutch cable released
Andync30
Post by Andync30 »
the clutch springs were changed with the plates.the needle bearing that pushes the push rod was completly shot as was the cable (which did snap)could these 2 things have caused this problem ?
MexicanGringo
Bike owned: '30
By clutch springs do you mean the coil springs on the back of the clutch housing? These are to dissipate vibration and dont affect the sandwiching of the plates.. The diaphragm springs are at the end of the pushrod and provide that sandwiching force to keep all plates together and not slipping once the clutch pushrod is released.. If they are worn, there might be insufficient force keep the plates together once the clutch is released
If you replaced the cable and bearing the prob should be fixed.. Maybe also check that the clutch nut is torqued sufficiently and staked so it cant move
Post by Neosophist »
What oil do you have in it, new fully synth can cause clutch slipping
hunter
Post by hunter »
What happens when you select higher gears,if it slips in the higher gears then it's the clutch.
