found a shock
				buzzawak
Re: found a shock
The R6 is 560lb/in and the fzr400U states the same 560lb/in but the 3tj is 336lb/inplodder wrote:Ignore me, I've got a 3TJ
The R6 shock has something like a 600 lb/inch spring and about 1.5" stroke (It's fkn solid)
Big differences
Do you happen the weight of a r6 shock (approx)? Want to work out the postage from US to Australia
Re: found a shock
Whatever the spring rates of other bikes the R6 shock is to hard for ther R6 as well !!!
				plodder
Re: found a shock
I've put a FZR1000EXUP aftermarket Nitron shock on the 4003TJ (seeing as I had one spare).  It has a 425lb spring and is pretty much spot on.
