found a shock
buzzawak
found a shock
I found a wrecker that has a 06-07 r6 shock and just want to comfirm with you guys it is infact
the right one? Cost is $225 australian dollars including postage so I want too make sure before I part with my money.
Re: found a shock
That's the one.
You need to round the bottom of it - it's squared
Put in some packing at the top (add a few washers each side
get new dogbones to raise the back end (by about 25mm)
The spring is hard so back the compression right off or get it changed
plodder
Re: found a shock
What bike is it for?
I put one of those on my 3TJ with Oolit's extension piece. It was OK but too hard for road use.
It now resides on my FZR1000 EXUP, for which it is just about right as it is 50kg heavier than the 400.
buzzawak
Re: found a shock
Its for a wg1plodder wrote:What bike is it for?
R6 shock seems to be the one everyone is recommending.
You recon its going to be too hard? It looks like a lighter
spring is in order then.
buzzawak
Re: found a shock
Hi Evil, Any diagrams (specs) of the replacement dogbones to return the bike to the default ride height ?Evilchicken0 wrote:That's the one.
Re: found a shock
nope sorry .... Toosmooth won some I think
toosmooth
Re: found a shock
LOL!Evilchicken0 wrote:nope sorry .... Toosmooth won some I think
...I thought you won them Mr Evil!!!
but I do have a step by step set of instructions that someone made about how to mount this shock, along with drawings for spacers and dogbones. it's for the FZR600 and at least the 3EN1 version of the 400 but I can send it on if you wish...
in fact, let me post a link to it http://www.visorvision.co.uk/downloads/ ... to_FZR.doc.
then you can all help yourselves. leave some loose change on the way out though!
cheers
toosmooth
- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
Re: found a shock
buzzawak
Re: found a shock
Thank for the info lajracing.lajracing wrote:Thats the one and you don't need the ooilt spacer for the r6 shock is the same lenth as the shock on your model... 3en 1 / 2 but 50mm too short for the 3tj
Someone happen to know the rate of the standard R6 spring?
I am (including gear) 75KG and my bike is used mainly for road riding so I am thinking I will need a lighter spring.
Any recommendations?
Are the Yamaha springs colour coded or marked in someway?
plodder
Re: found a shock
Ignore me, I've got a 3TJ
The R6 shock has something like a 600 lb/inch spring and about 1.5" stroke (It's fkn solid)
