fzr4001wg stator coils are they the same a the 600
ive got a feeling that my stator coils are shot but i have a knackered 600 engine sat in the shed which has still got the intact stator coils on it. the only problem is that the coils from the 600 sit in the the generator cover and not on the cranckcase like on the 400 anyone got any ideas
cheers martyn
cheers martyn
Re: fzr4001wg stator coils are they the same a the 600
I thought the 3HE and 1WG are similar they both sit inside the cover ... but maybe not the same in the details of the wiring.
The 3TJ has the magnetic windings on the crank end they're again similar to the 4JH but the wires come out the casing in a different place. The casings aren't interchangable because of that
the wiring comin fro the stator coil is exactly the same on the 600 as the 400
- Bike owned: 1990 fzr6 3he with a 4jh engin
The staor coils are different on a fzr6 3he to a fzr6 4jh as i found out when fitting a 4jh engine to a 3he engine same with the covers
- Bike owned: FZR 400 RR
Try this place for all sorts of coils and ignition parts you may be able to match a part up.
http://www.electrexworld.co.uk" onclick="window.open(this.href);return false;
