zx400 1988
quaidpinder
zx400 1988
Here is my zx400 1988 Which i have just purchased it has a tatty old exhaust system which i am trying to replace with difficulty ...
y
I have found a few parts on ebay but they are difficult to come across..
Johnny FireBlade
Re: zx400 1988
Very retro! Almost looks like Streethawk!
zimm
- Bike owned: some ZXR400's, ty175, mz ts125
Re: zx400 1988
ahh memories ..
thats exactly how ours looked 5 years ago, cept it had a titanium 4-1 exhaust on it (sadly long gone)
I really should get a standard screen again, looks way better.
look after it mate ! 9 month production run, import only, and the plastics (and yours look MINT!) are seriously unobtainable as kawasaki stopped making them years ago.
mechanically, its pretty much a zxr400 though, so oily bits are easy and cheap.
fantastic little bikes, 15kg lighter than a zxr with the same power :)
(and a fuel gauge)
(and a fuel gauge)
makaok
Re: zx400 1988
hi
i have one of those, trying to get exhaust down pipes was impossible, not the same as zxr. had to cut originl pipes and use original clamps and weld to zxr down pipes. trying to fit them this weekend. hope it works. one of the engines has a bigger sump. can you tell me what can be used from a zxr.
cheers
mal
cheers
mal
quaidpinder
Re: zx400 1988
Well after nearly 2 years of owning this bike & having a nightmare experiance with the frame
being full of filler after a smack that i didnt no about i have finally rebuilt the bike with a nonbent frame .. i have fitted a new exhaust system and given it a full service . its had new front discs new pads , my only headache now is some irratating wiring fault the indicator lights come on when the headlights are switched on ??? and i need to replace the throttle cable . will try and sort this then get her motd and ready for next year . not sure what the wiring fault it .. !
quaidpinder
Re: zx400 1988
Well just uncovered the bike after a couple of months of not looking at it and have found it to be not bloody starting it just turns over and will not fire up , starter motor turns over ok but nothing .. it does try you can hear it occasionally splutter .. thinking maybe fouled plugs or dicky coil .??I have tried the spark test in the dark with the ht leads but am failing to find a spark from number 3 ht lead / the leads are fairly brittle as well so it looks like i am in need of new coils and leads
.. Also just noticed some mayo substance on the oil cap but am assuming that this is due to condensation , its doesnt lose water or overheat... so i am hoping that it aint the head gasket !! i have removed the carbs to give them a good go over as this is one of those jobs i havent got round to doing yet , and am hoping with a cleaned carb and plugs n new coils and ht leads she will fire into life ... Although i just had another thought if the battery is dicky it may be the cause of the whole non starting issue weak battery would mean poor spark and cause this problem.?!
Anyone wih any helpful advice id love to hear it .. !
