RVF Engine gaskets
morganRVF
RVF Engine gaskets
Post by morganRVF »
Does anybody know where i can get a full OEM engine gasket set from for the RVF? The only place i have seen on the internet is Elliott MC but i's £160+. I can get a pattern set for £90? Will the pattern parts be o.k? If not a full kit can you tell me which gaskets i will need because i could probably buy them seperately.
Ian.
CRM
Admin NWAA
Admin NWAA
Re: RVF Engine gaskets
Post by CRM »
I think the general vibe is that pattern are ok, but always use genuine head gaskets with no exceptions.
davidsilverspares.co.uk have you tried them ? i would !
morganRVF
Post by morganRVF »
David Silver priced me up for 2 x Rocker Cover Gaskets, 2 x Head Gaskets, 1 x Generator Gasket and 1 x Clutch Gasket. For a full engine rebuild are they all the ones i need?
One other thing are the gaskets the same for the vfr and rvf?
