exup setting 3tj 400rrsp
matfzr400rrsp
Post by matfzr400rrsp »
anyone know where to set the little arm to on the exhaust exup valve? aint got a decent manual so ive just set it to where i thought.
Re: exup setting 3tj 400rrsp
Post by Evilchicken0 »
As you look at the pulley there's a hole at 9 Oclock .... stick a metal pin or small bolt between the two tougues and into the hole. Adjust the cables to finger tightness only ... and remove the pin ;)
Turn the ignition on to check the exup opens and closes properly
matfzr400rrsp
thought so, thats what ive done it to. thanks evil
