NC24 Valve Clearences?
christ044
Bike owned: NC24
Post by christ044 »
Just need to check iv measured the valve clearences in the right position.
I take it the gap is measured between the camshaft lobe and the little rocking arm?
Can anyone confirm this please.
Re: NC24 Valve Clearences?
Post by Neosophist »
Yup.
After you've lined the timing marks and cam marks into the correct place for the valves your going to check, slide your feeler gauge(s) into the gap between the rocker arm and the cam lobe.
Use a ring spanner to slacken the lock nut and then adjust the screw and tighten the locknut while using the screwdriver to keep the screw in place.
ALWAYS re-check after rotating the engine around.. there a bit fiddley to do first time but you'll get the hang of it.
christ044
Bike owned: NC24
Post by christ044 »
Good thanks for that iv been doing them right
Tell you what there a right pain to do when the engine is in the frame!
Haha yes they are.
The exhaust valves for cylinders 1 and 3 (rears) are the worst! Spesh if you leave the shock and battery box etc in :D
