3EN1 Front end swap?
Morespeedvicar
Hi,
I just wondered if anybody knows what front end would fit a road 3EN1 reasonably easily? My standard discs are well warped and fork seal has decided to to, so its gonna cost me about £400 to fix the front end, so i wondered wat you guys would think about doing a swap with something else?
Ian
Ian
- Motorcycle Solutions
- Bike owned: Kawasaki ZX9R E1
Re: 3EN1 Front end swap?
Hi
I can fork seals for £6 oil 1ltr £12 plus £3 postage and discs new i can supply too at a good rate or i might have second hand set if you like.
- cagiva996
if your front end is 41mm in diameter i have a 600 thundercat fully adjustable front end that would slot striaight in i also have the front wheel,which means you could use r1/r6 bluespot calipers(which i also may have)-dont want a fortune for it all just make some funds for hybrid2.pm me if your interested
I was going to say a ThunderCat bolts strait up. Use the complete front end (inc wheel and discs etc). You'll gain bigger discs better calipers and adjustable forks
