ing problem
- Bike owned: fzr600-,yzf750-,owo1,750
ing problem
Re: ing problem
Cracked carb mounting rubber? I had this problem once and it had the same symptons. Took me ages to sus it out, the carb rubbers did not looked cracked but were perished.
Re: ing problem
Check the battery is really good as at high revs the cdi/ignition uses a lot of power.
Also check if the tank is rusty & bits of shite are blocking the filter as I had this once.
Re: ing problem
Hi, makes sure the tank breather isnt blocked.
Ian
Ian
Re: ing problem
Thanks for the replys but still not cured,cleaned tank, fuel-tap new fuel filter,checked fuel pump,stripped carbs, all spotles still the same,when holding the throttle flat out it revs too the max then go's to 10000rpm
Re: ing problem
Ok so fuel seems ok .... how about electrics ???
Ckech the ciols ... can you swap them for another pair. Make sure the plug cap and HT leeads are all good and not got a weak connection anywhere.
Re: ing problem
thanks for the info problem solved, old ht leads, put some new leads on and she's singing again, :D
Re: ing problem
Cool glad it was a relativley easy problem to solve
