Can nc24 rear rim for vfr750f
abxxcd
Re: Can nc24 rear rim for vfr750f
NC24 -> VFR750
or
VFR750 -> NC24?
or
VFR750 -> NC24?
abxxcd
This is my nc24
aaah
Wheel will fit onto the hub, but depending on tyre fitted will hit the exhaust and chain (need modification)
it can be done!
it can be done!
abxxcd
Thanks!Do you once think to change it?Neosophist wrote:aaah
it can be done!
i have tried to do it.
can either
try to shim behind wheel to move it out,
move chain and sproket out more (may need more serious of work)
other side will hit exhaust pipe unless exhaust is twisted more outward (i used aftermarket can and custom link pipe)
can either
