The need for a fuel filter??
Does the fuel tap on a NC have a filter built in? if not can someone recomend one small enough to go between the fuel outlet on the tank to the fuel inlet on the carbs
viper_biker
Re: The need for a fuel filter??
There is one in the tap and the NC30 has a little filter on each carb unit as well (not sure about the 35 as you can't remove the screw to look) You can get small filters (I've seen a few on classics) but its not needed as the one in the tap will do the job.
thanks, i wont bother with an inline filter then, fuel tank is nc30 but i robbed the tap from a 35 tank, i'll cross reference the part numbers their probably the same.
carbs are NC35 too
carbs are NC35 too
