Front Brake Disc Torque Settings
snoopy89
Post by snoopy89 »
Hey Folks,
Long story short, my beloved and sacred Haynes Manual got destroyed when the roof on the garage failed to perform it's primary function. Boo Hoo Hoo, I know. :dmyspt:
Anyhoo, can anyone tell me the torque settings for the Allen bolts that hold the brake discs onto the front wheel please.
Cheers,
Aaron.
billnit
Bike owned: Not any more...
Re: Front Brake Disc Torque Settings
Post by billnit »
Only 22Nm for a NC35
Put some thread lock on too.
1996 Rothmans Rep RVF400 - 1997 Gilera Stalker 50 (soon to be "Malboro'd") - 2007 Honda Civic (manufacturer loyalty!!) - Audi A4 Avant S-line 2.0TDI - 1969 MGB GT
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
20nm mate!!!!!!
william
snoopy89
Post by snoopy89 »
Cheers Fellas. I appreciate your help.
:oops: Suppose I should've pointed out that it's a VFR400 NC30.So with that in mind 20 nm then?
Have got new bottle of threadlock all ready to go.
Thanks again.
Aaron.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
snoopy89 wrote:So with that in mind 20 nm then?
im pretty certain it's the same for both mate.
william
snoopy89
Post by snoopy89 »
Excellent. Thanks again.
snoopy89
Post by snoopy89 »
Managed to ring two bolts removing the old discs. Cock!
Any ideas on how to get them shifted?
theonefromthesky
Post by theonefromthesky »
Use an old Torx (star shape) socket thats just a little bigger than the allen fastner you have rounded and knock it in the hole with a hammer , then undo as normal. Its a bit "belt and braces" way out but 9 times out of 10 works for me on old bolts! Hence I allways keep a set of old Torx sockets handy! in the event that this fails, just get a 7mm drill bit and drill the heads off, chances are the threads arn't too tight and you can use a pair of mole grips to remove the remaining peice of stud.
Dont forget that a gentle appication of directed heat will almost allways help, a gas soldering iron with a flame tip is handy for small fastners or a propane/acetylene torch for the big stuff.
Jody
