Nc29 Electrical problem
lee-nc29
Post by lee-nc29 »
can some body please help?
i kept getting a flat battery so i got a new one fitted it started lovely, however it only lasted one day then it was flat so i charged it back up tested it the reading was 12.6v started the bike and left it running for 10mins tested the battery 12.3v even at 5000rpm it reads 12.3v. if i turn the lights on it drops to 11.7v as soon as i turn them off it goes back to 12.2v/12.3v.
I've checked the wires they all seem fine how do i test the rec/reg and alternator?
thanks,
Lee
missinNZ
Re: Nc29 Electrical problem
Post by missinNZ »
i believe haynes can explain how to test your reg/rec, sounds like this is the problem. or take it to your local and get them to check, i recently had same prob stemming from putting incorrect bulbs in and had to replace reg/rec, battery and starter solenoid. but yes those volts are way out.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
if you are getting no charge rate what so ever then it is more than likely the reg rec thats faulty.
william
lee-nc29
Post by lee-nc29 »
I've done some more tests and it is the reg/rec thats faulty so where can i get a cheap replacement from? or is there a mod that i can do?
lazcbr29
Bike owned: kawasaki ar 50, Honda CBR 125
Post by lazcbr29 »
if your after a new one
wemoto.com/graeme france/david silvers
laz
Gullarm76
Post by Gullarm76 »
With all the electrical problems I have been having I have done a lot of searching and found quite a few useful links. This one is good
http://www.cr-x.org/cbr250/forum/topic. ... C_ID=31226" onclick="window.open(this.href);return false;
One of the guys recommends an R1 reg/rec.
Anyone heard or tried this?
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
keep an eye on ebay for cheap ones that are in good working order of course ;)
also,graeme france on here will be able to sort you out with one i would have thought!!!!
william
leopard_pagan
Bike owned: CBR400/600 Fighter
Post by leopard_pagan »
i got a reg/rec from him 5 months ago. cant remember the cost but it wasnt much
lee-nc29
Post by lee-nc29 »
I've found a cheap one on ebay to get me going, its listed for a nc23 will it work on my nc29?
missinNZ
Post by missinNZ »
ive got a spare one i can do for £15 plus 2 50 for post. genuine honda part too.
