Nc29 Electrical problem
lee-nc29
can some body please help?
i kept getting a flat battery so i got a new one fitted it started lovely, however it only lasted one day then it was flat so i charged it back up tested it the reading was 12.6v started the bike and left it running for 10mins tested the battery 12.3v even at 5000rpm it reads 12.3v. if i turn the lights on it drops to 11.7v as soon as i turn them off it goes back to 12.2v/12.3v.
I've checked the wires they all seem fine how do i test the rec/reg and alternator?
thanks,
Lee
thanks,
Lee
missinNZ
Re: Nc29 Electrical problem
i believe haynes can explain how to test your reg/rec, sounds like this is the problem. or take it to your local and get them to check, i recently had same prob stemming from putting incorrect bulbs in and had to replace reg/rec, battery and starter solenoid. but yes those volts are way out.
wullvfr
- Bike owned: zx9r c1
if you are getting no charge rate what so ever then it is more than likely the reg rec thats faulty.
william
william
lee-nc29
I've done some more tests and it is the reg/rec thats faulty so where can i get a cheap replacement from? or is there a mod that i can do?
lazcbr29
- Bike owned: kawasaki ar 50, Honda CBR 125
if your after a new one
wemoto.com/graeme france/david silvers
laz
laz
Gullarm76
With all the electrical problems I have been having I have done a lot of searching and found quite a few useful links. This one is good
http://www.cr-x.org/cbr250/forum/topic. ... C_ID=31226" onclick="window.open(this.href);return false;
One of the guys recommends an R1 reg/rec.
Anyone heard or tried this?
wullvfr
keep an eye on ebay for cheap ones that are in good working order of course
also,graeme france on here will be able to sort you out with one i would have thought!!!!
william
william
- leopard_pagan
- Bike owned: used to have a NC29
i got a reg/rec from him 5 months ago. cant remember the cost but it wasnt much
lee-nc29
I've found a cheap one on ebay to get me going, its listed for a nc23 will it work on my nc29?
missinNZ
ive got a spare one i can do for £15 plus 2 50 for post. genuine honda part too.
