NC30 HRC-spec Ignition Boxes
Jon
Re: NC30 HRC-spec Ignition Boxes
Post by Jon »
Hi Rick
Could you email me the specs for the HRC curve, I should be OK with putting them in thanks.
Give me a shout when you have the carb bits sorted and I will grab them off you.
thanks
jon
Honda NC30
Ducati 900 S2 (under constrcution)
Moto Guzzi Le Mans III
Honda CB550F2
BMW R90S
Hi Rick,
Would you be able to send me the ign file too? I would like to try it against my DIY one.
I will send you mine if you are curious.... :geek:
cheers
RickOliver
Post by RickOliver »
Jon - Mailing those curves to you is on my `to do` list for the weekend - I`m afraid the engineer has put the delivery date for NC35 HRC kit components back to `end of March`...
Mark - I`m not sure that we know each other well enough to get into an `I`ll show you mine if you show me yours` scenario... :oops:
RickOliver wrote: Mark - I`m not sure that we know each other well enough to get into an `I`ll show you mine if you show me yours` scenario... :oops:
Now, come on Rick.... :shock: :? Did I get the wrong end of the stick... :o
RickOliver
Just teasing - I`ll send them over at the weekend... :lol:
blanc
Post by blanc »
Hi
A few qs, the box is fully progeammable, does it come with two maps installed? Normal and HRC for the 35? I have a set of Marawaki pipes I presume I should use the HRC Map for track use. Do you need to rejet and if so is there a carb kit available?
james66
NOT TO BE TRUSTED
NOT TO BE TRUSTED
Post by james66 »
Hi all
I know its digging up an old thread
Just wondering what sort of results they had from fitting these?
i people could list their mods + the power gains over std ignition i would greatly apreciate it
James
2013 Bemsee EDIasia F400 Sub64 Champion :)
NC30 + NC35 RS250 HRC aluminium rear axle group buy
viewtopic.php?f=78&t=45065&start=10
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
Review:
http://www.400greybike.info/newforum/vi ... a&start=10" onclick="window.open(this.href);return false;
