Poor running
badbannedbiker
Bike owned: nc29 nc30 gsxr750 T675 CRF450
Poor running
Post by badbannedbiker »
Right....I've acquired myself a 73a sp project. Before I go buying Oring kits etc etc I thought I'd post a topic incase anyone has any ideas.
the 73a sp I bought has a running problem, It starts and idles fine but won't rev - if you give it a big handfull of throttle 8 out of 10 times it bogs and dies - and if you can tease the revs up high enough to pull away it then loses power and dies.
So far I have - changed the plugs (NGK CR8EK-s), taken the diaphragms out and cleaned the jets, vacuum slides and needles of some varnish using a specialized carb cleaner spray (haven't removed float bowls buts sprayed plenty of stuff down the jets) and checked the fuel tap and air filter. when you have the bike running and rev it the vacuum slides chatter quite a bit also.
Any ideas before I start stripping the carbs?
jake_gsxr
Re: Poor running
Post by jake_gsxr »
i'm pretty sure my bikes running cr9ek spark plugs so that might be having an affect???
badbannedbiker
Re: Poor running
Diaphragms are a bit stretched at the top where they fit into the carb bodies and seal against the black top lid....? :?:
The ones I swapped out were 8's, and I'm sure thats what the manual said, can anyone confirm this?
Gazz
Re: Poor running
Post by Gazz »
Hi
I've taken this from a GK73A Service manual, hope it helps.
Gazz
badbannedbiker
Re: Poor running
where'd you get the manual may I ask? Would this make a massive difference? anyone want to buy a set of 4x cr8ek used for 5mins? :D
badbannedbiker
Re: Poor running
the bike had being sitting for a year or so,so I'm assuming its more likely to be a carb issue than the cdi dieing (can they just go for know reason?)
cdi maybe??
cheers
reggit
Re: Poor running
Post by reggit »
Spark plugs won't matter at this stage. The 8 and 9 are just the heat rating of the plugs.
Most likely a blocked jet(s) in the carbs. I'd whip 'em apart for a look see.
Honda CB1000 'Big One'
Yamaha RD350LC
badbannedbiker
Re: Poor running
thats the next step I think, got to get a o ring kit off variablevalvesuck. Any body know where I can find diaphragms and float gaskets? Is it worth me buying cr9's just yet as cr8's came out of the bike? Do you think its worth
spending £35 getting the cdi tested at this stage?
badbannedbiker
Re: Poor running
anybody know where i can find a rocker cover gasket?
Gazz
Re: Poor running
Post by Gazz »
Try these guys for parts.
http://www.ridersmotorcycles.co.uk/index.html" onclick="window.open(this.href);return false;
