weird headlight problem
Talon
the bike just randomly picked up a fault a few weeks ago, need to get it fixed now because its going for mot.
the sidelights work fine, but when you go to main beam it stays on sidelight. full beam still works fine if you push the button in. now obviously i need a main beam.
any ideas?
any ideas?
Re: weird headlight problem
Strip and clean the switchgear - lots of WD should see it right
wullvfr
- Bike owned: zx9r c1
have you removed the bulbs and visually inspected the element?
the bulb could have blown,but full beam would still work.
william
william
- Sligeach
exactally as the boys said. had the same problem a few weeks ago on the ZX6.
i took out the bulb and fuses, both fine.
i took the switchgear and all connector blocks for the lights and drenched them in contact cleaner, then a water repellant (some muc off stuff) and worked a treat.
i didnt actually see any dirt per se, but it fixed it, so i'm happy
Talon
ok thanks for the replies you three, will give it a try tomorow and let you know how it goes.
very helpful site, thanks. :D
Talon
Re: weird headlight problem **update**
**update**
took the switchgear apart, and gave it a good squirt with some wd40 but it still hasnt sorted the problem?
though it sorted the horn out so thats one less thing for mot time.
- Matchlessman
What happens if you go from dipped to main? it does sound like the bulb has gone on the dipped element.
Too many bikes, so little time!
Talon
earier it was switching off for a scond then coming back on, but now it doesnt it just alternates with no gap.
wullvfr
make yourself a jumper wire,get a piece of wire and bare it at each end!!!!
remove the block connector coming from the switchgear and the side going to the lights start to bridge the terminals....
try different combinations and your lights will start to work.if your main beam works this way then you know for sure the switchgear is faulty.
william
william
