Propping up the vfr
challymo
Propping up the vfr
Post by challymo »
I have the vfr up on the abba stand, and i can't seem to keep the front up in the air without putting weight on the back. Is there a way i can keep the front end up without a front paddock? or headstock support?
Re: Propping up the vfr
a jack under the pipes mate.. sorted
challymo
Post by challymo »
what like a car jack. i was just worried that would damage the pipes.
TonyB
Bike owned: NC30, CBR900RRY
Post by TonyB »
Just put a flat bit of wood on the jack head to spread the weight over the pipes. Done this many times with no damage.
Dynamohum
Post by Dynamohum »
and that way you'll soon find how good your mid-joints are lol :!:
TonyB
Post by TonyB »
davethetrucker wrote:and that way you'll soon find how good your mid-joints are lol :!:
In that case, use a piece of wood that fits between the pipes and take the weight on the sump.
NC
Post by NC »
Dont worry mate seems a bit crude but been using trolley jack for this for years ,got mine on the abba at the mo will be getting the trolley jack out myself to do the forks very soon
Pete
mattUKNC
Post by mattUKNC »
You can get the wood to sit on the right side sump points, so you don't have to touch the exhaust. I cut slits into the wood so dropped straight on, no worries. :D
matt_vfr
Bike owned: '89 NC30
Post by matt_vfr »
When i did my forks i just got someone to hold the back of the bike down and put a plank of wood under the headstock, in the little crevice behind the bottom yoke. Slot the plank in there and let the other end sit on the floor! Just make sure to cut it to length! The centre of gravity is only just in front of the swingarm pivot so it doesnt take a lot of force to prop the front up... i wouldnt worry about damaging anything too much, however you want to prop it!
Matt
