vfr single sided swingarm on a nc23
jolley1982
hi i was wondering if anyone has done this conversion and how hard it is to do also what swingarm is best to do it with any info really apreciated as i dont really want to buy one to find out its impossible thanks guys
squirrel_hunter
Re: vfr single sided swingarm on a nc23
Don't do it. There is nothing wrong with it. The NC23 is defined by its swing arm. If you want a single sided 400 buy a VFR.
Having said that anything is possible with the correct sized hammer.
I don't know if it has been done however you want any info... Considerations: width of the arm pivot compared to the frame, is it too short, too wide, will you need a custom spindle or spacers? Is the length of the arm from pivot to hub different, will it effect the geometry? Will the hub sprocket line up with the front sprocket? How does the rear shock of the VFR compare to the NC23, which would you use, is it offset, longer or shorter, will the ride height be affected?
If you want to do it best advise I can give is with that in mind buy a VFR arm and shock and hopefully wheel from eBay and then line them up and see what happens. If it doesn't work stick them back on eBay, don't overpay and worse case you should make most of your money back. Alternatively take some measurements of the NC23 arm and compare that to the VFR measurements. I think the VFR has already been measured on this site, or at least elsewhere on the interweb as single siders are used frequently in projects.
HTH
HTH
jolley1982
thanks for the advice Squirrel hunter
squirrel_hunter
If you do go for it please keep us updated.
rider4life
- Bike owned: Vfr 400 nc30
i noticed this nc29 has a vfr 400 swingarm fitted. i asked him about it but he said he purchased the bike like that and didnt even know.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=016" onclick="window.open(this.href);return false;
squirrel_hunter
Good spot.
From the quality of the pictures and description in the ad I'd say he didn't have a clue what he had. I'd also guess that he invalidated his insurance with an undeclared mod and the assessor knew about as much about bikes as he does.
So from the above we can see it is possible (assuming it is a VFR400 arm, I'm not an expert and can't tell from those photos) to fit one to a NC29. Thus we can extrapolate based on the interchangeability between the NC23 and NC29 arms. Anybody know if you can swap them over and any work required to do so?
jolley1982
some great advice if i can get a vfr400 swing arm setup cheap enought i am gonna have a go at doing it just gotta keep searchin ebay i think thanks for all the help so far and well spotted on the nc29 one
- Jon
NC30 and NC35 swingarms are different, not sure which will be closer to the NC23 dimensions.
The shock is offset to the left on both of them to give exhaust clearances
jon.
regard
jon.
regard
jolley1982
cheers for then diagrams jon i will try to measure mine to see which is closest
joshmolloy
zombie thread, sorry. Did this ever get anywhere? I have an NC23 frame and an NC30 swingarm, wheel and shock, and was thinking about trying to put something together.
