NC29 REG/REC
badbannedbiker
Bike owned: nc29 nc30 gsxr750 T675 CRF450
NC29 REG/REC
Post by badbannedbiker »
hi have a couple of queries. Will a broken cooking fin on my regulator damage it or stop it working? Also does it need to be mounted to the steel subframe or is my alloy undertray ok???
lloydiecbr
Bike owned: VTR1000
Re: NC29 REG/REC
Post by lloydiecbr »
broken fin will be fine . when you remount it make sure you got a good earth to bolt it to i would of thought . i might be wrong . but its always worked for me
badbannedbiker
Re: NC29 REG/REC
cheers mate problem solved.
Cheers!
leopard_pagan
Re: NC29 REG/REC
Post by leopard_pagan »
bolt it BACK to the frame..... the frame acts as an extended heat sync...... heat syncs dissipate the heat generated.
tanuki
Re: NC29 REG/REC
Post by tanuki »
anywhere is fine really although the standard place on the exhaust hanger is probably the best, my old NSR one with Tyga tail used to barely touch any metal at all and that was fine.
