simmo's bikes :) zxr getting a FULL rebuild for next season!
- simmo
Re: simmo's bikes :), ZXR RE-BUILD REPORT, feel free to comment
cheers, im still going to be using the stock m/c.mrdidlydingo wrote:Pads are EBC I use them in everything, just the standard range though in the ZXR as its my 'everyday' bike used for everthing road and the odd trackday but its my pet so never gets too much hassle on track, I'm therefore probably not the best man to speak with regarding pads.
The stock ZXR master cylinder seems to work fine no excess travel or wooden feel, my old kwak calipers were pretty tired so I used to get spongy brakes real fast buying these were cheaper than rebuilding them hence swapping them over.
i think the pads that are in them are EBC so ill try them out on a practice day.
@ CMSMJ1, where can you get nissin pads from? im guessing they are the Honda pads??
cheers
simmo #98 - JSRacing
Road ~ NC30
Race ~ ZXR400
- simmo
fitted the new calipers today, and bled them.
they feels loads better!!
and i bought this, thoght it would look cool with the new paint job
Road ~ NC30
Race ~ ZXR400
looking good, but you can get that front tyre over a bit more on the left lol
Howdo matey - they were from my local shop and a "std" pad for these calipers. Took less heat up than the EBC and were superb in all conditions.simmo wrote:
cheers
The armstrong pads would feel like wooden blocks and then grip and fade almost instantly. Took them out fairly quickly..lol
- mrdidlydingo
Std ZXR master cylinder ? which bolts did you use in the end ?
They look the nuts on the ZXRs as if they were supposed to be there !
Top job keep goin !
Top job keep goin !
- simmo
cheers,
std zxr master cylinder, i used the gsxr disc bolts for now, need to get some Honda caliper bolts,then will use them with the sleves.
how far did you have to space out the calipers, and what did you use?
Road ~ NC30
Race ~ ZXR400
- mrdidlydingo
I'll have a look for the caliper bolts mate, may have some hanging about !
I used stainless washers they only need moving a millimeter or so to centre the caliper and centre bored bright bar but trying to get some machined all in one piece as attaching them like that will make a grown man cry !
I'll whip one off and take a pic !
hi simmo my name is gary an i'm from ireland, i have d same farings as u an ram air tube, jus woundering how your rad is done i cannot seem to find any 1 over here willing to cut it an weld it, if u no of any 1 that wouuld be able to cut and weld it??
- Bike owned: some ZXR400's, ty175, mz ts125
cut, fold, araldite :)
thanks i'll give that ago
