HELP- i have a nc30. been offered a set of good nc35 forks..
- Vzzzbuxt
i have a nc30 . been offered a set of good set of just serviced nc35 (USD) forks and yokes cheap (cheap=£200 but need to let him know today!!)..
question is...how easy would they be to bolt into the nc30?
initially the answers im after are
# yoke stem the same? i.e will it bolt straight in or need a spacer machined or stem swap
# is the nc30 wheel and discs the same dimentions etc? ( ill source callipers elsewhere so not bothered about them now) i could always get a rvf front wheel etc later to finish it off!
# front spindle and spacers??
other things like i know id need clipons etc anyway are important at this time .. its more that i need it a rolling chassis due to current storage space limitations.
also whats a standard full nc30 front worth to recup some cash. (well whatever is leftover/ i dont need for the above)
cheers
j
cheers
j
its not a race, okay?... READY-STEADY-GO!
__________________________________________________________________________________________
the current 'fleet' is:_#/ BMW R1100s _#/ TL1000 streetfighter [/b] VFR400 NC30 [FOR SALE] NC30 [big CC 'twin' project ]
Re: HELP- i have a nc30. been offered a set of good nc35 forks..
You need a fitting kit from Rick Oliver - PM him on here.. stems are different
Wheels and discs are the same.
Internally they are pretty much the same...
You need the spindle and spacers too I believe
front end worth from £50 to £100 if you are lucky...
- Vzzzbuxt
cheers for the advise, ill go another way.
in hindsight i may give it a miss...
