NC30 HRC-spec Ignition Boxes
Jon
Re: NC30 HRC-spec Ignition Boxes
Post by Jon »
Turned up today thanks Rick.
Would be interested in seeing the NC35 HRC map if you get the info, offer still stands if you want a hand getting the info.
regards
jon
Honda NC30
Ducati 900 S2 (under constrcution)
Moto Guzzi Le Mans III
Honda CB550F2
BMW R90S
Dumbledore Calrisian
Post by Dumbledore Calrisian »
Hi Rick,
fairly new around here, from the land of Oz, was wondering how much would it cost landed in Sydney (Post code 2035) for an NC30 model with USB connector?
I understand that these are a plug and play so am very interested.
If we can come to an arrangement it'll be in the new year so no rush,
Merry X-mass.
Nate
RickOliver
Post by RickOliver »
That would be no problem, Nate - you`ll see from the previous post that I`ve just sent one over for Jon.
Mail me r.oliver(at)mtxnet.co.uk and I`ll send you a price list...
Rick
Hi Rick
Any progress on the NC35 units as ar as the programing issues are concerned?
RVF007
Post by RVF007 »
as above, any update on the NC35 boxes?
You can get the boxes without any preloaded maps on them and program it yourself...
The HRC maps were on a graph on here
nolie
Post by nolie »
my bike is an nc35 but runs an nc30 tuned motor with no alternator,race loom and i think it has nc30 ignition pickups . is it possible to fit the nc30 unit instead of waiting for the nc35 to be finalised.
Jon
Post by Jon »
If you have NC30 pickups you want one of Rick's CDIs that is programmed to suit those pickups, if the HRC advance curve becomes available you can then change the advance curve to its specs if you wish.
Does you current CDI box have wires coming from it running to two plugs (NC30) or the loom plug straight into its base in one large built in plug (NC35)?
The only physical difference between the NC30 and NC35 boxes Rick is selling is the plug so you need to buy to suit that plug, the rest is programming.
regards
jon
Honda NC30
Honda CB550F2
BMW R90S
nolie
Post by nolie »
cheers jon, im not sure about the double plug on the cdi,il check tomorow.im fairly sure i remember there only being one plug tho when i was having trouble with the loom. would you say theres any advantage in having the later nc35 electrics because my bike seems to be a mixture of who knows wot ! if theres no difference im gonna change everything to nc30 as that seems to be more sorted out and il at least know whats on the bike. i think my bike was wired by the wombles :lol:
Cammo
Post by Cammo »
nolie wrote:would you say theres any advantage in having the later nc35 electrics because my bike seems to be a mixture of who knows wot !
The nc35 electricals are more reliable in my opinion, definitely improved over the nc30 (hell, the nc30 cdi is held together by rivets!!).
