Dog leg Levers - Do both clutch and Brake hit the fairing?
marty400
Post by marty400 »
Hiya All,
RE:NC29 - Dog leg Levers - Do both clutch and Brake hit the fairing?
I remember someone telling me that at full turn, the modified Puzzi Dog leg Levers actually touches the front fairing. Fine for Race bikes, or the experienced - you never turn that much. But not good for a newbie bike - we do the strangest things!
Is this hitting the fairing for both sides though??
It has hit me. I only need it for the Clutch side. (Small hands - clutch not fully dis-engages, before my Hand comfortably lets go. A problem on a long ride - tired hand, clutch controls suffers and bike does lurches on careless gear changes etc!)
I reckon a bit of tinkering before summer 2009 arrives!
Hope you can advise!
Martin
PS:
I would have rang up GF about this straight away - but its the holidays for christ sake! leave the poor chap alone! 8)
chrisja2
Bike owned: nc29 trackbike
Re: Dog leg Levers - Do both clutch and Brake hit the fairing?
Post by chrisja2 »
Make sure your clutch lever is at the right angle, to far up and you get wrist cramp!
Chris.
marty400
Post by marty400 »
chrisja2 wrote:Make sure your clutch lever is at the right angle, to far up and you get wrist cramp!
Chris.
Good Point Chris! I'll take a look!
Thinking about it, would just one dog log lever on a bike just look wrong, or would you even notice?
Do people do both or not at all?
Martin
leopard_pagan
Post by leopard_pagan »
for race.. no problem..
for road.. MOT failure.
even on a U turn you dont quite lock the steering. i do find when i wheel the bike i use full lock.. and TBH if something fouls the fairings on my bike= paint job damage!
marty400
Post by marty400 »
leopard_pagan wrote:for race.. no problem..
Hiya LP,
Long time no Speak! (I rode the CBR4 last weekend and I'm totally bike mad again! 8) )
Good points
I'm hoping the Clutch side is ok though. I'm really struggling with the "Wide Hand" clutch lever - tried doing the adjustments - no luck.
Martin
leopard_pagan
there is a cheat or 2.... only *if* your going to MOT it..
you can drill a hold through the steering stops, put a thread in the holes and then a bolt. adjust the bolt to lock the steering before they levers hit... after MOT..remove the bolts.
another way would be to make a spacer to lock the steering that slots over the lock stops to avoid drilling holes.
stimpy
Post by stimpy »
from memory you can get proper steering stops that just bolt on from hrc..there maybe another manufacture doing them also
stimpy
