New to forum,
New to forum,
Hello people,
Hope you can help, have a 1992 import nc30 that had sat for 10 years spent 3 months working on it . Finally got it started motd the other day broke down on way home, the symptoms are will just about start when hot, then revs ok for a few minutes then starts to miss any throttle she just dies, when cold can start her ok will tick over in neutral for 15 mins ok.
Then I tried to ride it starts to miss and dies.
Tried lots of checks plugs ok new reg/rec tested coils wires look ok.any help would be much appreciated.
Re: New to forum,
Welcome to the forum
There are people on here who know far more than me but you haven't mentioned the carbs. I assume that if the bike has sat for 10 years then you've obviously stripped, cleaned and rebuilt them with new parts?
Re: New to forum,
Sounds fuelling rather than electrical?
You might have to get brave and get the carbs off for a clean and check it's not been fiddled with too much
Does the vacuum hose "suck" properly to open the fuel tap? No splits in it?
