Flasher relay
BillyBarcelona
Flasher relay
Post by BillyBarcelona »
Hi folks, renovating the old 1992CB400sf and the previous owner (a bit of a bodger from what I've found so far), had installed LED flashers. I have now put the proper bulb flashers back.
The flasher relay had been replaced to a 2 pin type and the earth wire taped up. My question is, do I need a new flasher relay, and if so, do I buy an original 3 pin, or is there a 2 pin one available using the same wiring method for my bulb type?
Hope I've made myself clear.
Thanks in anticipation.
Andy
magg
Bike owned: VFR400
Re: Flasher relay
Post by magg »
Have you tried using the as fitted 2 pin relay to see if the bulbs flash correctly. I would leave the flasher running for a few minutes to ensure it is reliable.
