NC24 wiring issue
- Reactions:
NC24 wiring issue
Hi first post I'm rebuilding an NC24 from scratch, so far I've got the engine in and front end on and swing arm, so I've come to the wiring loom and didn't realize that the engine I have is a K so it has the neutral gear sensor/switch with the 5 wires now I'm stumped coz the loom doesn't have any facility for the wires, so I'm guessing I'm going to have to add these to the loom, so getting to the point has anyone done this and could help me out with a wiring diagram of some sort or info on what to do, thanks in advance any help is greatly appreciated
- Reactions:
Re: NC24 wiring issue
Can you upload a pic of the sensor and plug?
What is the engine number? This will identify exactly what engine it is.
Is the CDI unit Denso or Mitsubishi? Located next to the battery or under the pillion pad?
- Reactions:
[/img]Hi it's an OKI MLO lot.no. 7520
- Reactions:
Did you fix this.
This issue has been covered before.. I can dig out the post with the answer
