Bike running like a bag of shit
wullvfr
- Bike owned: zx9r c1
Re: Bike running like a bag of shit
if you want to do a simple test to see if the alternator is goosed or not,for future reference
get the block connector by your right knee and test the three pins coming from the alternator but instead of the test you done this time test it to see how much voltage the alternator is putting out
for this you need to set the multimeter to ac volts..........because the readings of the alternator should be 50volts+ make sure the multimeter is set to a range high enough if it gives you the option.
with the bike @5000rpm take three seperate readings(3 pins)and they should all be 50volts or above,if any are below or different from the others then the alternator is goosed and i guarantee it will look like the stator windings in the pic cmsmj1 posted
william
william
1990nc30
can you get a reading off the pins in the little box with the bike running?
Cheers!
Cheers!
wullvfr
yes it has to be done with the bike running as this is when the alternator is producing the ac voltage...........
william
william
