Threads in plug hole are gone!
zimm
- Bike owned: some ZXR400's, ty175, mz ts125
Re: Threads in plug hole are gone!
sod easy-outs .. chances are it'll just snap ..
get a big torx bit (splined) and tap it into the remainder of the plug, then unscrew. simple.
had it happen a couple of times on a zxr
- brooky
- Bike owned: cbr400,vfr400,crf250,ktm200exc
ive done it before with an eziout but due to the depth of the plug hole you will need to weld it to a socket, dont even need the engine out the bike that way. Try it first if it fails i have a spare head.
Vinylmark signs - for all your bike, car, van, vinyl needs, one off tshirts also printed.
http://www.vinylmarksigns.co.uk" onclick="window.open(this.href);return false; email sales@vinylmarksigns.co.uk
Waza4
Ask around a few local engineering shops.
scoops
I got a lad up to have a look at it today, he welded a bit onto an easy out and got the bit of the plug out. Threads are grand!! Im a lucky Git!!!
Cheers for advise and tips guys
Dumbledore Calrisian
Seeing as i'm a retarded moron, it looks like i've done the same thing. Sheared the head of my spark plug off inside the head. Will be welding up a tool tomorrow at work and see how i go.
Will let you know if god hates idiots tomrrow.
zimm
big torx bit in a socket with an extension eliminates all this welding malarky !
just a thought
just a thought
As luck would have it, god loves a retard. Welded up a screw extractor to a bolt and got the head of the spark plug out, new one in, purs like a kitten.
I'll post up picks of my shitty welding tomorrow,
would also like to add, that at $19 wholesale, this is the most expensive spark plug on the planet this side of the iridium range.
wtf?
what were honda thinking when they created a motor that needed such a unique spark plug that it doesn't fit anythign else?!?
wtf?
Ahh..but it fits the NR750 too.Dumbledore Calrisian wrote: would also like to add, that at $19 wholesale, this is the most expensive spark plug on the planet this side of the iridium range.
wtf?
Only the best and smallest plugs for the mighty V4
