Honda cbr 400 nc29 petrol tap
Hi guys and gals have a problem with my honda cbr400 nc29 when petrol tap is in the on position if you move it there's a slight leak from the face held in by 2 screws ???, also do you need too drain the fuel tank to strip it down for repair thanks
- Bike owned: NC29 CBR600F
Re: Honda cbr 400 nc29 petrol tap
If you are repairing the fuel tap you will indeed need to drain the fuel tank as the tap is the only thing stopping the fuel flowing. Is it definitely from the gasket?
If you're going to strip it anyway, why not give the 2 screws just a tiny tighten? Just an incey-wincy bit.
Cheers guys , needed to rebuild it with new seals
