NC30 Remove rear Lower engine mounting bolt
ebachs10
Hi All
I'm troubling removing the rear lower engine mounting bolt and hope you can help me out, solving the problem.
I have removed the nut on the lefthand side and the castle nut on the righthand side.
Can I hammer it out from the left side of the bike or is it screwed into the frame? (It is not clear to me, via the manual).
Thnaks in advance!
Pictures:
https://ibb.co/ct31GBD
https://ibb.co/0XJmhzF
https://ibb.co/CQb3mXy
/Esben
Thnaks in advance!
Pictures:
/Esben
vic-vtrvfr
Re: NC30 Remove rear Lower engine mounting bolt
Put the nut back on a few threads and hit it a smack with the hammer to loosen it up. Hitting the pin directly will damage the threads
- Tim400GB
Get some penetrating fluid too, dont want to be doom and gloom but Ive helped a friend cut one of those out before
