A question of model
- Variablevalves suck
Re: A question of model
It should have pipes from the float bowls that connect to a pipe that comes from a small black vacuum switch (box) that is on the air box.
This will open and pressurise the float bowls as the airbox pressure changes.
Tiked12345
Will there be any restricters on it ?
Tiked12345
Restrictions?
They only have 180 kph limit that has usually been removed by importer or owner.
Restrictions?
Restrictions?
Tiked12345
Thanks I've seen a couple of pictures of sp models and they have some silver piping from under the tank that look as if they go to the side fairings like air intakes my bike does not have these present bout 40mm diameter
That's just the fake air intakes and unimportant.
Tiked12345
Thanks for the help am goner start working on it in a few weeks when I've finished my other bike need to source a few parts for it to £££££
Tiked12345
How will I know if the restricters have been removed will they stop it from revving right out or is this just in the last gears that it will . Will it still redline in neutral
