Rear Hub Removal
wingy1962
Rear Hub Removal
Team
Having trouble getting the main shaft with brake rotor out of the rear hub. I have searched the topic and the best I found was penetrating oil and a wallop with a rubber hammer. I have done this method to death and still no movement. And yes have the wheel and sprocket carrier off. I even tried a big lump of wood up against the shaft on the left side of the bike and a big metal hammer, and still no good. I'm scared of damaging the shaft or threaded end.
I did however get the center shaft/bolt out that holds the wheel on.
Is there a way someone has used with a type of bearing or wheel puller?
Any advice would be appreciated.
Thanks and regards,
Tony
Thanks and regards,
Tony
Dynamohum
Re: Rear Hub Removal
Strange one that can only think that the bearing spacer that sits behind the sprocket has seized onto the shaft or the bearings themselves would try bolting the wheel back on and pulling on that would give more purchase or using the wood over the inside of the wheel and hammering .
wingy1962
Thanks for the idea, I have organised a bearing puller so will give that a try too.
Thanks for the info.
Regards,
Tony
Regards,
Tony
wingy1962
Borrowed a two leg bearing puller and did the job easy. there was a red grease inside that had gone solid and looked the culprit. Cleaned out easy with penetrating oil, then re-greased bearings, changed the rear brake disk and pads and put it all back together.
Regards,
Tony
Regards,
Tony
