NC30 Stop/Tail light issues (SOLVED)
magg
Bike owned: VFR400
Re: NC30 Stop/Tail light issues (SOLVED)
Post by magg »
Simplysideways, the same issue, both stop lights on unless you press either the front or rear brake levers and then they go out?
Simplysideways
Post by Simplysideways »
magg wrote: Tue Nov 13, 2018 11:08 am Simplysideways, the same issue, both stop lights on unless you press either the front or rear brake levers and then they go out?
They don’t go out they slightly flicker
magg
Bike owned: VFR400
Post by magg »
So lights OFF, ignition ON and stop lights come ON immediately and pressing front or rear brake levers causes stop lights to flicker.
Simplysideways
magg wrote: Tue Nov 13, 2018 10:15 pm So lights OFF, ignition ON and stop lights come ON immediately and pressing front or rear brake levers causes stop lights to flicker.
My lights are permanently on when the ignition is turned on ( from memory lol only picked up a few weeks ago and only had the tail cone on once ) , the taillights are extremely bright and when I press the brake there is a slight change/ flicker in brightness.
I’m up in Cairns at the minute and the bike is in Brisbane so I won’t get a chance to have a look at it until the weekend again , depending on what the wife has in store for me when I get home lol.
Cheers mate
magg
Bike owned: VFR400
Post by magg »
NC35 is lights on always, NC30 not. You have an NC30 or an NC35?
Simplysideways
magg wrote: Fri Nov 16, 2018 3:14 am NC35 is lights on always, NC30 not. You have an NC30 or an NC35?
It’s def an NC30 jap import , lights are permanently on . There is no switch to turn them off .
magg
Bike owned: VFR400
Post by magg »
The left handlebar switch should have three positions, Dot (off), P (park) and H (headlight). Not aware of any NC30 with lights always on.
Simplysideways
magg wrote: Sat Nov 17, 2018 11:09 pm The left handlebar switch should have three positions, Dot (off), P (park) and H (headlight). Not aware of any NC30 with lights always on.
Mine must have been swapped out at some stage because where your talking about is blocked up , Gonna be looking at a RVF to buy during the week so i’ll Have something to compare to .
magg
Bike owned: VFR400
Post by magg »
The switches do fail when high wattage bulbs are used as there is a relay on only high beam, and people use an NC35 as a replacement. Needs some rewiring to work and may indicate that there are other wiring idiosyncrasies.
Simplysideways
Thanks mate ,
I ended up buying an RVF400 so the missus can ride it due to her license , needs a few bits doing so gonna focus on that for now and put the VFR in storage and make it a long term project / use as a spares bike
Def an RVF switch fitted so I’ll prob chase us a proper switch for it , guessing as with a lot of Honda parts they are generic between different models of that era CBR400rr/CBR250rr
