Irregular Idle Speed
Mansie
Reactions:
Bike owned: CB400 Four NC36, NT650V
Post by Mansie » Fri Nov 02, 2018 1:51 pm
There is something not right with the Idle system. For a while now I had to run it at ~2500 rpm, whereas the manual says 1200 rpm. However, if I set it to 1200 rpm the engine will surely cut out. I had the bike serviced but driving back I noticed the idle increased to 3500 rpm. So back at home, with the motor warmed up on my drive I set the idle back to 2000 rpm. The next day I set off and during my journey the engine cuts out every time I pull the clutch lever in and revert to idle, the revs go below 800 and the engine cuts out. Only if I reset the idle speed to 3500 rpm or above will it not cut out. My mechanic said he had to rebalance the carbs so I assume that works correctly. This weekend I will check the air feed into the idle system. Any other suggestions?
Suzuki416
Reactions:
Bike owned: 3 x NC35, 3x NC24, NC29, RC46
Re: Irregular Idle Speed
Post by Suzuki416 » Fri Nov 02, 2018 10:08 pm
Carbs - idle jets & or syncing
Mansie
Reactions:
Post by Mansie » Mon Nov 05, 2018 9:46 am
Thanks for the reply. Yes, idle jets are prime suspects, and vacuum connectors. I had a look over the weekend and squirted some carb cleaner into the air intake. I was lucky, all is running smoothly now.
