Weak / intermittent spark
freeserve
Bike owned: vfr400 nc30
Post by freeserve »
Hello,
I am after some troubleshooting help please, :peace:
Bit of background:
This is a very long term project, +5 years now. I purchased the bike as 5 boxes of bits and frame witch turned out to be UK spec.
The bike is now built (mostly) and is, or was just about a runner. After getting the bike fired up I noticed it was not reving past 4 - 5K, when I tried to push past this the bike would try to stall but I also noticed it was not running on one of the cylinders. I put this down to Carbs which are beyond me so I got them all fixed up by GF Racing. awesome job :plus:
Crabs all sorted but now it refusing to fire up, after checking for spark I realised I had at best a very weak spark but most of the time I had no spark at all. Plugs are new, HT leads are new, coil packs are tested in accordance to the manual.
Not sure where is the best place to start with this issue so any help would be very much appreciated bighug
Regards,
John
NGneer
Re: Weak / intermittent spark
Post by NGneer »
1. Check all your earths and plug connections (Have you painted or powder coated bits like the sub frame which could now be preventing a good earth connection?)
2. Try working through this (http://www.electrosport.com/media/pdf/f ... iagram.pdf) as that will guide you through checking most of your electrical system. If you get through that without finding anything wrong then start looking at the more obscure options such as the ECU possibly breaking down.
magg
Bike owned: VFR400
Post by magg »
Speedo plugged in?
freeserve
Post by freeserve »
magg wrote:Speedo plugged in?
Yes mate.
Sent from my SM-G950F using Tapatalk
freeserve
Post by freeserve »
NGneer wrote:1. Check all your earths and plug connections (Have you painted or powder coated bits like the sub frame which could now be preventing a good earth connection?)
Thanks, I will work through it and see if it helps.
moforockband
Bike owned: GK73a SP CRM250 mk3
Post by moforockband »
check the 12v and ground at the cdi. Also check that the coils both have 12 volts, and that the grounding wire on each coil measures 0 ohms when continuity checked back to the cdi (unplugged).
Obviously check that the sidestand switch/neutral cutout isn't causing you any grief.
freeserve
Post by freeserve »
moforockband wrote:check the 12v and ground at the cdi. Also check that the coils both have 12 volts, and that the grounding wire on each coil measures 0 ohms when continuity checked back to the cdi (unplugged).
Thanks, I will check it out.
Post by Neosophist »
what ignition box are you using? jdm boxes have a speed limiter which cuts the rev limit after 5500rpm.
apart from that pretty much what everyone else has said, since its a new build check the earths, re-check battery voltage.. kill switch.. try some other plug
strange one!
freeserve
Post by freeserve »
Standard unit, thanks everyone. I will check everything over the next few days.
